Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
General Earlybay Chat
Retrosounds review + speakers
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Mags" data-source="post: 557009" data-attributes="member: 13104"><p>I bought a 2 way toggle switch from eBay with 3 connectors, one is the switched 12v from the fusebox (ignition) one is the ignition wire on the head unit the other is the 12v from the leisure battery, so it's either getting 12v from the leisure battery to keep it switched on or from the ignition when the bus is running depending on the switch position.</p></blockquote><p></p>
[QUOTE="Mags, post: 557009, member: 13104"] I bought a 2 way toggle switch from eBay with 3 connectors, one is the switched 12v from the fusebox (ignition) one is the ignition wire on the head unit the other is the 12v from the leisure battery, so it's either getting 12v from the leisure battery to keep it switched on or from the ignition when the bus is running depending on the switch position. [/QUOTE]
Verification
Post reply
EarlyBay Forums
