Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Running wires in camper - what have you done
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="lard" data-source="post: 528577" data-attributes="member: 13096"><p>Hi - I also thought I could get a wire up into the roof through the C pillar but couldn't find a route through - apparently the light in the cab runs down the A pillar above the fuse box, my setup had 3 fuse boxes:</p><p></p><p>LB via inline fused wire to a small fusebox under the R&R bed</p><p>along to the buddy seat with the main fusebox and connection for a charger to the 240v hookup</p><p>then from the buddy seat up under the dash to a 3rd fuse box powering stereo e.t.c.</p><p></p><p>I plan to take a connection off the front fusebox and replace the orignal wire to the lights, and use this for the other lighting connections</p><p></p><p>hope that helps</p></blockquote><p></p>
[QUOTE="lard, post: 528577, member: 13096"] Hi - I also thought I could get a wire up into the roof through the C pillar but couldn't find a route through - apparently the light in the cab runs down the A pillar above the fuse box, my setup had 3 fuse boxes: LB via inline fused wire to a small fusebox under the R&R bed along to the buddy seat with the main fusebox and connection for a charger to the 240v hookup then from the buddy seat up under the dash to a 3rd fuse box powering stereo e.t.c. I plan to take a connection off the front fusebox and replace the orignal wire to the lights, and use this for the other lighting connections hope that helps [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
