Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Rust bubble
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="oldbuser" data-source="post: 609097" data-attributes="member: 22757"><p>The problem with a rust ‘bubble’ is that the rust has come from underneath the paint. You may find when you rub/sand the paint down you will have a rust hole. If you just fill this it will only come back. Cutting out and welding a repair in, maybe a bottom door skin repair panel will be the only long term solution.</p></blockquote><p></p>
[QUOTE="oldbuser, post: 609097, member: 22757"] The problem with a rust ‘bubble’ is that the rust has come from underneath the paint. You may find when you rub/sand the paint down you will have a rust hole. If you just fill this it will only come back. Cutting out and welding a repair in, maybe a bottom door skin repair panel will be the only long term solution. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
Rust bubble
