I bought a blast pot from msb blasting and spent months getting frustrated with clogging, also the media is obscenely expensive to deliver.
I got Some cheaper media from someone that was too big for the metering nozzle and drilled it out a little, I still couldn't use the media but I then found a suppler of crushed glass close enough to drive to, since then it's been a brilliant bit of kit, and as I blast on tarps, I sweep it up and reuse the glass.
I'm not suggesting you need to drill the valve out but it's been much more reliable for me now.
The only 2 negatives are it consumes huge amounts of air, I'm using a pretty large compressor but it can't keep up and I have to pause every couple of mins to allow the pressure to build up in the pot again and unless the pot is full of media it doesn't seem to work quite as well.
Having said all this it's been a great bit of kit, I've saved so much on my bus by blasting and painting.
Mags
