Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Seam Sealer...?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="geoffsurf" data-source="post: 155786" data-attributes="member: 1061"><p>Thanks guys for you advice. Very tricky area as there seems to be lots of different opinions on whats the best way and products.</p><p></p><p>Bare metal vs Painted</p><p>Brushable vs Tubed</p><p></p><p>I actually have POR15 and was hoping to use that on the underside of the car. I have already used it for the curved area between the floor and outer sill. Would it be good to apply metal ready and then try and jam POR15 between the spot welds of the new inner sill and floor or is etch primer better?</p></blockquote><p></p>
[QUOTE="geoffsurf, post: 155786, member: 1061"] Thanks guys for you advice. Very tricky area as there seems to be lots of different opinions on whats the best way and products. Bare metal vs Painted Brushable vs Tubed I actually have POR15 and was hoping to use that on the underside of the car. I have already used it for the curved area between the floor and outer sill. Would it be good to apply metal ready and then try and jam POR15 between the spot welds of the new inner sill and floor or is etch primer better? [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
Seam Sealer...?
