Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Setting end float on a brand new engine build.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="mr scoops" data-source="post: 591237" data-attributes="member: 14100"><p>All sorted. I needed to use 4 shims, and was advised by Dan Simpson along with the company that build the engines for Heritage.</p><p>Endplay measured at 0.08mm</p><p>Should have been 0.1mm but I'm guessing the oil between each shim etc made up the overall 0.02mm</p></blockquote><p></p>
[QUOTE="mr scoops, post: 591237, member: 14100"] All sorted. I needed to use 4 shims, and was advised by Dan Simpson along with the company that build the engines for Heritage. Endplay measured at 0.08mm Should have been 0.1mm but I'm guessing the oil between each shim etc made up the overall 0.02mm [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
