Loxy
Anyone got a pic of a fitted original set showing bracket location ?
(with a tape measure along each edge would be amazing )
wibbler said:Loxy, if you look at the brackets on stu's ( the ones up the side of the window) and take a measure from the top of the black trim panel the bottom bracket is at 6 3/4" and the top is 10 1/2".
Measure half inch from the window rubber for your first hole and your pretty much there. The bottom brackets will be pretty self explanatory once the side brackets are on.
Hope that helps.
mcvw said:Anybody know where you can get the rear luggage-bars from? Could do with a set for my deluxe.
