Speaking with someone at the weekend who really knows what hes doing, he told me how to easily narrow a bay beam sulbtley ('extreme' narrowists need not read on )
He just said to remove the trailing arms, knock off the grease seal housing and then grind/cut back the housings to the first 'step'. Then tap the bearing in a bit further and re-fit the trailing arms - and cut/redrill one end of the leaves. Put back together using generic o-rings for grease sealing and youve lost about two inches simply and without excessive work.
Ive had a look at a beam today with this in mind, and it looks too good to be true. Anyone done it? Any glaringly obvious concerns?
Ta
Ta
