Solar panel
Yes, I have a 100W flexible solar panel on my 71 tintop roof.
The cables go through the air intake and are linked to a 103Ah AGM battery on the left of the engine.
I have full autonomy with a Dometic CFX28 cooler, phone, laptop, etc.
I'm in the process of installing a 100w rigid panel on the luggage rack of our westy. Using a votronic controller that also charges the starter battery
Sent from my Pixel using Tapatalk
are you planning to install this below or on the rails?
It has been installed on the rails and working great!
Cheers for the photos. i use my rack all the time so i am looking at a portable one.
I did ask about them last year but still haven't got round to sorting it.
You could possibly do something with a flexi panel underneath but a standard would be too thick. You would have a lot more time in shadow though. Sticking to the poptop is a popular option
I did think about a flexi panel but hook it to the pop top when its up as i didn't want to stick it to the roof. They are great a few mate have eriba's and use them.
I was the same about sticking it on which is why I went with the rack. I thought about detachable but then it is taking space in the van and you have to remember to put it on.
There is still a bit of space around it that I can use, could be increased further by mounting in a corner rather than central. You could also fashion a bracket to allow it to be attached further back.
I use 100w Poly rigid and carry it in the Bus as i use the Roof rack, when i set up it goes on the roof and wires drop down the cooling vents
