Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Sound system dummy!!
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Steve B" data-source="post: 564510" data-attributes="member: 19255"><p>Well, if you're keeping the van, then a decent headunit, new, will be between £120-£180 (more if you want!) Speakers maybe £40>£70.</p><p></p><p>In simple form, for 50w output, speakers around 120w + will b fine. Although as mentioned above, you can check RMS level. When buying online, RMS specs are always supplied on the details for the product. </p><p></p><p>To learn more about RMS, just Google 'headunit RMS guide'. Plenty of threads with similar questions to yours.</p></blockquote><p></p>
[QUOTE="Steve B, post: 564510, member: 19255"] Well, if you're keeping the van, then a decent headunit, new, will be between £120-£180 (more if you want!) Speakers maybe £40>£70. In simple form, for 50w output, speakers around 120w + will b fine. Although as mentioned above, you can check RMS level. When buying online, RMS specs are always supplied on the details for the product. To learn more about RMS, just Google 'headunit RMS guide'. Plenty of threads with similar questions to yours. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
