69 Campers
Active member
Hello
Any pointers out here for refurbed boxes, internal parts if possible to replace ?
Thanks, spoken to Graham he can't get the parts to refurb@Graham L at Midland Early Bay does steering box refurbs.
I used a guy on Facebook.Thanks, spoken to Graham he can't get the parts to refurb
as far as I’m aware no one is making RHD worms not even N2 engineering, the LHD worms made by a supplier in Europe are terrible and work opposite to how they should work.Thanks, spoken to Graham he can't get the parts to refurb
They don't list changing the worm though and for that cost I would expect the worm to be changed, they are aware of the issues with the remade worms as I've had conversations with Rick about them.![]()
Steering Box 68-72 RHD, Rebuilt. 214-415-049E
Fully rebuilt steering box, fits all Bay window 68-72 (anything low indicators) RIGHT HAND DRIVE This is a used original box which has been completely stripped and cleaned, the original worm meticulously inspected and checked for wear, then we machine the case and output shaft to allow 2...www.alanhschofield.com
£600 inc a £200 exchange surgharge. They also do pegs and other refurb parts to diy
We had RHD & LHD worms made a few years ago, they were good but not perfect, something changes on the spriral to change the stiffness at the centrepoint of the box and they did not spot it and as I said the worms from a European manufacturer are even worse where they get looser in the middle rather than tighter. (the idea is the box gets stiffer as it gets to the middle to give you a positive centre feel in the straight ahead position and then loosens as you turn left or right)@Graham L could you have a UK engineering co. make the worm drives (LHD & RHD) for you?
Yeah, I was lucky enough that when I took mine off (as the steering was really slack) it didn’t turn out to be that bad. Once I adjusted it up it was acceptable. Someone had it set up so with the wheels at dead ahead the peg wasn’t even on the ”tight spot” on the worm. As you say the worm has to be machined with less clearance in that central area.They don't list changing the worm though and for that cost I would expect the worm to be changed, they are aware of the issues with the remade worms as I've had conversations with Rick about them.
They're not in stock, you need to call them. I think they wait for enough orders and then get a batch made.Hi @Graham L have you seen or tried the advertised new LHD top quality worm drives from coolairvw?
https://www.coolairvw.co.uk/product/211415205f/
Its the same one everyone else stocks from BBTHi @Graham L have you seen or tried the advertised new LHD top quality worm drives from coolairvw?
They are made by BBT but as traders we are finding that parts suppliers are not holding stock unless they have to, this was Machine 7's downfall, taking orders & peoples money telling people things were in stock and then the next day emailing to say that they hadn't got stock, at least Coolair are being honest, if you contact them they say they will get one in.They're not in stock, you need to call them. I think they wait for enough orders and then get a batch made.
Register today and take advantage of membership benefits.
