Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Steering Damper Split & Box Mounting Cracked - Lucky Escape
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Graham L" data-source="post: 497936" data-attributes="member: 3481"><p>I think the pinch bolt is a HT bolt and theres a torque setting in the manual for it, there should be a crack down the side of the coupling as that lets you slide it over the splines on the box before tightening the pinch bolt.</p></blockquote><p></p>
[QUOTE="Graham L, post: 497936, member: 3481"] I think the pinch bolt is a HT bolt and theres a torque setting in the manual for it, there should be a crack down the side of the coupling as that lets you slide it over the splines on the box before tightening the pinch bolt. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
