Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Stock exhaust question
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Tofufi" data-source="post: 626031" data-attributes="member: 38"><p>Don't forget reproduction heat exchangers are... pants, when compared with OE <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1" alt=":)" title="Smile :)" loading="lazy" data-shortname=":)" /></p><p></p><p>If it's just the outer skin that is holed, they can be repaired. Don't skimp on them though, as if the exhaust pipe is leaking inside, you'll get exhaust fumes in the cab...</p></blockquote><p></p>
[QUOTE="Tofufi, post: 626031, member: 38"] Don't forget reproduction heat exchangers are... pants, when compared with OE :) If it's just the outer skin that is holed, they can be repaired. Don't skimp on them though, as if the exhaust pipe is leaking inside, you'll get exhaust fumes in the cab... [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
