Strange shims between spring plates
panalvan
Jan 10, 2007
649
ipswich suffolk
Anyone seen this before between the spring plate and hub/bearing carrier there are two shims they look like they have been there from factory .Question is has anyone seen this before and do i put them back?Ive not seen this before when restoring my other vws.You can see the marks on the spring plate and hub
Can't imagine a shim that small doing anything but I think washers are sometimes used to prevent negative camber.
Mine had them.Did'nt bother refitting them when i put on the ajustable spring plates no negative camber or problems.
Stuart
