Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
T1 / Beetle Case into Bus Adapter Options?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Cali_bay" data-source="post: 593761" data-attributes="member: 3991"><p>Hi, this is what I came up with, full flow oil pump cover and mounting bracket. I drew up the design and a friend machined it up for me. It uses the four pump studs plus a u clamp round the lower case bolt. Has worked well with my 2027 stroker. </p><p></p><p><a href="https://postimg.org/image/xkptapou5/" target="_blank"><img src="https://s22.postimg.org/dq3rol9mp/20130428_092410.jpg" alt="" class="fr-fic fr-dii fr-draggable " style="" /></a></p></blockquote><p></p>
[QUOTE="Cali_bay, post: 593761, member: 3991"] Hi, this is what I came up with, full flow oil pump cover and mounting bracket. I drew up the design and a friend machined it up for me. It uses the four pump studs plus a u clamp round the lower case bolt. Has worked well with my 2027 stroker. [url=https://postimg.org/image/xkptapou5/][img]https://s22.postimg.org/dq3rol9mp/20130428_092410.jpg[/img][/url] [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
