Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Timing - 30 deg BTC?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="davla" data-source="post: 616804" data-attributes="member: 27260"><p>So I set the timing to 7.5 BTC using a timing light (with vacuum pipe off) and reset the carb screws (PICT34) to 2.5 turns out on each and it ran fine, after a few miles I had to screw in the bypass screw a bit to slow down tick over but it's not pulling away too bad tbh. I'll see how it goes. Thanks for the advice</p></blockquote><p></p>
[QUOTE="davla, post: 616804, member: 27260"] So I set the timing to 7.5 BTC using a timing light (with vacuum pipe off) and reset the carb screws (PICT34) to 2.5 turns out on each and it ran fine, after a few miles I had to screw in the bypass screw a bit to slow down tick over but it's not pulling away too bad tbh. I'll see how it goes. Thanks for the advice [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
