Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Timing clarification required
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="six" data-source="post: 558356" data-attributes="member: 13557"><p>whs ^ 28-29 is about right. personally run accuspark svda. 28.3 at full advance. when idling should fall back to about 7.5 bdtc. </p><p></p><p>you need over 3000 rpm, vac plugged. wind it up till you think thats loud that will piss the neighbors.. then a little bit more, that should be about right. just keep them rpms steady</p></blockquote><p></p>
[QUOTE="six, post: 558356, member: 13557"] whs ^ 28-29 is about right. personally run accuspark svda. 28.3 at full advance. when idling should fall back to about 7.5 bdtc. you need over 3000 rpm, vac plugged. wind it up till you think thats loud that will piss the neighbors.. then a little bit more, that should be about right. just keep them rpms steady [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
