Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
General Earlybay Chat
To lite steer or not to lite steer
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="cunning plan" data-source="post: 611907" data-attributes="member: 4090"><p>On a technical note, does anyone how do these units work out of interest?</p><p></p><p>On a simple level, I presume it senses movement of the wheel and multiplies the force applied to the steering box.</p><p></p><p>However, on a more detailed level, how does it do it? Is there a physical connection from the unit to the steering column to detect movement, then an electric motor drives a series of gears connected to the steering column (how?) to help power the turn? :?: </p><p></p><p> <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite7" alt=":p" title="Stick out tongue :p" loading="lazy" data-shortname=":p" />opcorn:</p></blockquote><p></p>
[QUOTE="cunning plan, post: 611907, member: 4090"] On a technical note, does anyone how do these units work out of interest? On a simple level, I presume it senses movement of the wheel and multiplies the force applied to the steering box. However, on a more detailed level, how does it do it? Is there a physical connection from the unit to the steering column to detect movement, then an electric motor drives a series of gears connected to the steering column (how?) to help power the turn? :?: :popcorn: [/QUOTE]
Verification
Post reply
EarlyBay Forums
