Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
TransporterHaus Spring Plates - Initial Position????
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="subheatadey" data-source="post: 498194" data-attributes="member: 20105"><p>Remember that one outer spline drop + or - will lift lower the bus approximately 42mm to get fine adjustment you need a combination of inner and outer such as taking the outer 1 spline and the inner forward or backward depending if you want it up or down you can get fine adjustment, remember what you did so you can repeat it on the opposite side or use a angle finder? Chart below is from Volksworld, as i mentioned when i moved mine 1 outer spline it was 42mm.</p><p><a href="http://s1289.photobucket.com/user/subheatadey/media/Sunroof%20Bus%20Z%20bed%20and%20Brackets/Sunroof%20Deluxe%20Bus%201971/Splineadjustmentchart_Page_1_zps0f044139.jpg.html" target="_blank"><img src="http://i1289.photobucket.com/albums/b517/subheatadey/Sunroof%20Bus%20Z%20bed%20and%20Brackets/Sunroof%20Deluxe%20Bus%201971/Splineadjustmentchart_Page_1_zps0f044139.jpg" alt="" class="fr-fic fr-dii fr-draggable " style="" /></a></p></blockquote><p></p>
[QUOTE="subheatadey, post: 498194, member: 20105"] Remember that one outer spline drop + or - will lift lower the bus approximately 42mm to get fine adjustment you need a combination of inner and outer such as taking the outer 1 spline and the inner forward or backward depending if you want it up or down you can get fine adjustment, remember what you did so you can repeat it on the opposite side or use a angle finder? Chart below is from Volksworld, as i mentioned when i moved mine 1 outer spline it was 42mm. [url=http://s1289.photobucket.com/user/subheatadey/media/Sunroof%20Bus%20Z%20bed%20and%20Brackets/Sunroof%20Deluxe%20Bus%201971/Splineadjustmentchart_Page_1_zps0f044139.jpg.html][img]http://i1289.photobucket.com/albums/b517/subheatadey/Sunroof%20Bus%20Z%20bed%20and%20Brackets/Sunroof%20Deluxe%20Bus%201971/Splineadjustmentchart_Page_1_zps0f044139.jpg[/img][/url] [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
