Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Tuning engine help
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="thejinx" data-source="post: 578894" data-attributes="member: 15775"><p>Ok. Valves set</p><p>Timing set </p><p>Still loosing power once hot. </p><p></p><p>I am thinking spark plug gap as I wasn't really ofay with engines when put this together or possibly a lead braking down. Cheap VeeWee parts. Or even the throttle set up wrong and not opening the carb enough</p></blockquote><p></p>
[QUOTE="thejinx, post: 578894, member: 15775"] Ok. Valves set Timing set Still loosing power once hot. I am thinking spark plug gap as I wasn't really ofay with engines when put this together or possibly a lead braking down. Cheap VeeWee parts. Or even the throttle set up wrong and not opening the carb enough [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
Tuning engine help
