Not so much a problem just wondering ? on start up from cold when revving a bit the carbs seem to sort of pop/cracking sound almost a slight hesitation from idle a small pop and then fine ! does this a few times until either a good few stamps on the throttle or a good blast up the rd for a few hundred yards ? is this just the fuel getting to them or a fueling/timing/ balanceing issue ?
once normal tickover is achieved all is fine ?
Also once warm when dropping down a gear or just takeing foot off the throttle the exhaust pops a bit on the overrun dunno if its because its a fairly large back box with 4 into 1 header or again timing/fueling issue ?
valves,plugs,points are all good
vac advance dizzy (svda) timing reaches about 36 degrees full adavance and 6 degrees on tickover .
Have read that the svda dizzy can reach as much as 40 degrees advance ( dunno how true this is )
like i said no major problems just your thoughts if you please
