Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Twin ICT Balance Pipe?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="georgeyv" data-source="post: 594842" data-attributes="member: 22226"><p>Hi all - </p><p></p><p>Finally getting round to fitting my Weber ICT carbs in the next couple of days - just making sure I've got all the correct bits but one thing I'm unsure on (even more unsure after reading so much divided opinion) is the balance pipe between the carbs.</p><p></p><p>I've got CB manifolds with 1/8 bsp threads tapped in. I have no fittings yet so will buy those. Who has these fitted and what size tails/hose have you used? How is it routed? Any help greatly appreciated.</p><p></p><p>Thanks!</p></blockquote><p></p>
[QUOTE="georgeyv, post: 594842, member: 22226"] Hi all - Finally getting round to fitting my Weber ICT carbs in the next couple of days - just making sure I've got all the correct bits but one thing I'm unsure on (even more unsure after reading so much divided opinion) is the balance pipe between the carbs. I've got CB manifolds with 1/8 bsp threads tapped in. I have no fittings yet so will buy those. Who has these fitted and what size tails/hose have you used? How is it routed? Any help greatly appreciated. Thanks! [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
