Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
**update 2**finally got the video uploaded to you tube.....
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="sharky71" data-source="post: 483335" data-attributes="member: 13974"><p>SO AS HEADING STATES UPDATED......</p><p></p><p>I fitted the woodruf key as explained early and seamed quieter but ran for about 10 mins and the niose came back so off i went to the local Auto Electricians and it's an engine out job <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite3" alt=":(" title="Frown :(" loading="lazy" data-shortname=":(" /> <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite15" alt=":cry:" title="Crying :cry:" loading="lazy" data-shortname=":cry:" /> </p><p></p><p>So i've pulled the engine and have checked oil deflector plate to double check correct fitting(see earlier thread about weeping about 3 months ago),yes it was fitted correctly and Dynamo is off but my question is how do you get the bloody fan off the back???</p><p>Obviously it keeps turning,should i have took it off when still attached to bottom crank pulley??</p><p>I can not see how you put it on iether if it again is fitted when shroud is in place.</p><p>Looked in Bentley and unless i am missing something it does not show/tell me how to go about it,also what tool to use.</p><p></p><p>Any suggestions??</p></blockquote><p></p>
[QUOTE="sharky71, post: 483335, member: 13974"] SO AS HEADING STATES UPDATED...... I fitted the woodruf key as explained early and seamed quieter but ran for about 10 mins and the niose came back so off i went to the local Auto Electricians and it's an engine out job :( :cry: So i've pulled the engine and have checked oil deflector plate to double check correct fitting(see earlier thread about weeping about 3 months ago),yes it was fitted correctly and Dynamo is off but my question is how do you get the bloody fan off the back??? Obviously it keeps turning,should i have took it off when still attached to bottom crank pulley?? I can not see how you put it on iether if it again is fitted when shroud is in place. Looked in Bentley and unless i am missing something it does not show/tell me how to go about it,also what tool to use. Any suggestions?? [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
