bit of diagnostics for u if u can please guys ... ok so the problem that i was having with my bus is when i planted my foot down it would hesitate under load and there is a lack of power also when i hit the slightest hill now iv changed the dizzy iv got the 009 on it from gsf and iv got powersparks dizzy also here with me with elec ignt but that just seems to pop and bck fire when timed up ,replaced fuel pump filter and lines ,new coil,and obv new dizzy ,set the valve clearences and what not pretty much done everything now on the way down to pod weekend it was running a little flat i was doing 60 65 max down to pod and when i came off at woolaston it didnt want to know it had no power what so ever and was back firing if i planted my foot in first it nearly cut out ..now on the way home it was so bad it still had no power what so ever it back fired in everygear under load and i had to kill each gear to get up to motorway speed and when i hit a slight hill or put my foot down in 4th doing 50 ,60 mph it just bckfired all the way up the motorway and now it sounds ****** the engine when i turn it over sounds dead ..could really do with sum ideas as iv ran out of ideas and all the shows are comming up and it sounds fckd any ideas as iv checked for vaccume leaks and what not ? cheers guys
