Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Vintage Speed Shifter problem
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="rlepecha" data-source="post: 568247" data-attributes="member: 19679"><p>If you lift the rubber boot there are two screes under this, wind them both in until the bottom out( very light pressure!) Then back them both off a small amount. Pull up on the shifter and it returns smoothly, if not back them off a little more and try again.</p><p></p><p>This should reduce the movement to a few mm either way. </p><p></p><p>See http://shop.vintagespeed.com.tw/core/media/media.nl?id=15589&c=3504492&h=7cba36d226a83db55dfc&_xt=.pdf" onclick="window.open(this.href);return false;</p><p></p><p>Sent from my C55 using Tapatalk</p></blockquote><p></p>
[QUOTE="rlepecha, post: 568247, member: 19679"] If you lift the rubber boot there are two screes under this, wind them both in until the bottom out( very light pressure!) Then back them both off a small amount. Pull up on the shifter and it returns smoothly, if not back them off a little more and try again. This should reduce the movement to a few mm either way. See http://shop.vintagespeed.com.tw/core/media/media.nl?id=15589&c=3504492&h=7cba36d226a83db55dfc&_xt=.pdf" onclick="window.open(this.href);return false; Sent from my C55 using Tapatalk [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
