Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Weber carb conversion issues
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="mike202" data-source="post: 590233" data-attributes="member: 17202"><p>It sounds ok in the second half but not the first. You may need to adjust the choke if you have one. I added one to mine but it worked ok without a one for quite a while. The choke is quite difficult to reach as it's round the back against the fan housing. Mine is an electronic choke by the way which is adjusted by loosening the mounting bolts and rotating it to suit. </p><p></p><p></p><p>Sent from my iPad using Tapatalk Pro</p></blockquote><p></p>
[QUOTE="mike202, post: 590233, member: 17202"] It sounds ok in the second half but not the first. You may need to adjust the choke if you have one. I added one to mine but it worked ok without a one for quite a while. The choke is quite difficult to reach as it's round the back against the fan housing. Mine is an electronic choke by the way which is adjusted by loosening the mounting bolts and rotating it to suit. Sent from my iPad using Tapatalk Pro [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
