Done this twice now :shock: once to paint the floor and second to fit new ply panels.
It's not too bad, remove sink unit first. You will have to probably loosen the drain pipes fitting under the bus. Mine has a small metal plate held on with two self tappers. Then undo the vent cover so you can manoevere the vent pipe that goes through the roof. Then there are two hand nuts that go through the driver's seat stand.
Next remove the buddy seat: 4 bolts on the floor.
You will need to remove the table after this, and the table leg holder on the floor so you will be able to slide out the R&R bed.
Then you'll need to take out the R&R bed. There's quite a few bolts with this; about 4 on the floor under the seat, two little ones on the wheel arch and one sneaky one on the wardrobe side right up the top underneath. Then there are four bolts for the hinges on the back deck, behind the seat. It's quite heavy and it's better if you have a helper to remove it from inside the bus. The arm rest is only accessible after removal of the bed.
Next headbanger shelf unit, there are two screws on the left or window side, and a hand bolt on the right.
Then you can take out the wardrobe which will have two fastenings near the small door, and one at the rear. Don't think there's any more.
Enjoy! get a helper!! :mrgreen:
