aogrady
Hi!
After the last 2 batches were sold, I am able to get some more westy mozzy net in if anyone else needs any? A pair will be £7 posted. Should be a few weeks before it arrives.
it looks exactly the same as OG AFAIK. It's grey in colour, and easy to replace as it is held in with a rubber tube a few mm thick all around a groove in the window, as shown below. Pull the old tubing out, and lay the mesh lined up, and slowly press the tube back in the groove, as you work along, it will tighten up and be crease free. I used a chop stick to press in the groove - you may find something else with a blunt end is as good.
I have done my own, and it looks great, easier than trying to clean the stuff - and it's normally a bit fragile and torn after 35 plus years!
Add yours names to the thread, and i will post more details when i arrives!
Cheers!
Alistair
Cheers!
Alistair
