Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
What ceiling lights with vinyl roofs?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="NoPower-NoResp" data-source="post: 462902" data-attributes="member: 18245"><p>I've got a birch roof and have replaced all the bulbs with leds. I have the standard westy three bulb light in the back (switchable between 0,1,2 and 3 bulbs) and the roof light in the cab with one more bulb. I would say it is more than enough. We normally switch on just one or two bulbs as full power is a bit much.</p><p></p><p> The eBay description...</p><p></p><p>White Dome 9 LED 5050 SMD Interior Bulb Light 42mm</p><p></p><p>It keeps the og look <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1" alt=":)" title="Smile :)" loading="lazy" data-shortname=":)" /></p><p></p><p>Sent from my Nexus 5 using Tapatalk</p></blockquote><p></p>
[QUOTE="NoPower-NoResp, post: 462902, member: 18245"] I've got a birch roof and have replaced all the bulbs with leds. I have the standard westy three bulb light in the back (switchable between 0,1,2 and 3 bulbs) and the roof light in the cab with one more bulb. I would say it is more than enough. We normally switch on just one or two bulbs as full power is a bit much. The eBay description... White Dome 9 LED 5050 SMD Interior Bulb Light 42mm It keeps the og look :) Sent from my Nexus 5 using Tapatalk [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
