Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Which Brake Servo
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Trikky2" data-source="post: 585614" data-attributes="member: 240"><p>It's a well known issue.</p><p>You can make a 'C' clip that holds the two cables closer together so it just clears the servo.</p><p>You may need to slightly slacken the cable adjustment afterwards if the handbrake travel is too short.</p><p></p><p>In addition you may find you need to use a grinder to reduce the stub on the axle assy if it fouls the other side of the servo.</p></blockquote><p></p>
[QUOTE="Trikky2, post: 585614, member: 240"] It's a well known issue. You can make a 'C' clip that holds the two cables closer together so it just clears the servo. You may need to slightly slacken the cable adjustment afterwards if the handbrake travel is too short. In addition you may find you need to use a grinder to reduce the stub on the axle assy if it fouls the other side of the servo. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
Which Brake Servo
