Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Which carbs for a 1641
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="jonboylaw" data-source="post: 537736" data-attributes="member: 17621"><p>The Dells are very good carbs. Once set up you should not have to touch them. No electric choke is not a big problem for me. Use a quality low pressure electric pump (Huco is my recommendation) and a cut off solenoid with an inertia switch and it will be very reliable. Having said all that, you are looking at around £600 for that lot which if you are on a budget or don't see the benefit could be an issue. So a single PICT carb, jetted right can be put together for a few quid ( get the jet files to make your own jets). Yo could even machine the choke/Venturi if you feel brave. This would help it breath a little.</p><p></p><p></p><p>Sent from my GX64 SatCom phone using Tapatalk</p></blockquote><p></p>
[QUOTE="jonboylaw, post: 537736, member: 17621"] The Dells are very good carbs. Once set up you should not have to touch them. No electric choke is not a big problem for me. Use a quality low pressure electric pump (Huco is my recommendation) and a cut off solenoid with an inertia switch and it will be very reliable. Having said all that, you are looking at around £600 for that lot which if you are on a budget or don't see the benefit could be an issue. So a single PICT carb, jetted right can be put together for a few quid ( get the jet files to make your own jets). Yo could even machine the choke/Venturi if you feel brave. This would help it breath a little. Sent from my GX64 SatCom phone using Tapatalk [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
