Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Will a 1973 door fit a 1969?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Doris" data-source="post: 317995" data-attributes="member: 4049"><p>Yeah,73 will have a push button (looks like a little golf tee) on the top of the doorframe by your elbow like a 68 only...69 -73 has the unlocking mechanism as part of the interior door handle (not door pull) also *I think* the interior door handle is in a slightly different place so you'd need the matching rods to the door you'll be fitting or drill some new holes and use nuts and bolts instead of the factory captive nuts.</p><p></p><p>So in a nut shell , yeah it will fit, but you need to change a few things and (if you're bothered) it won't be 'right' for the year.</p><p>Hth</p><p></p><p></p><p>Sent from my iPhone using Tapatalk</p></blockquote><p></p>
[QUOTE="Doris, post: 317995, member: 4049"] Yeah,73 will have a push button (looks like a little golf tee) on the top of the doorframe by your elbow like a 68 only...69 -73 has the unlocking mechanism as part of the interior door handle (not door pull) also *I think* the interior door handle is in a slightly different place so you'd need the matching rods to the door you'll be fitting or drill some new holes and use nuts and bolts instead of the factory captive nuts. So in a nut shell , yeah it will fit, but you need to change a few things and (if you're bothered) it won't be 'right' for the year. Hth Sent from my iPhone using Tapatalk [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
