I have an electric washer pump which I can hear working but no water comes out of the nozzles.
There is water in the reservoir and the nozzles are clear.
There is no trace of water leaking down under the bus.
There is a small hole in the washer cap which I believe ought to be there but whether its blocked or unblocked makes no difference.
After crawling underneath I can't see the reservoir, either because I'm stupid or the pans are in the way, I suppose the latter could trap any leaking water.
The last time this happened was just before the MOT when the guy doing it blew air through which fixed it then. I've tried this but don't have access to an airline and it didn't work with a normal pump.
Any ideas?
Any ideas?
