Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Winter repairs
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Bluesnailman" data-source="post: 648231" data-attributes="member: 17859"><p>I went for the Csp shifter because it looked most like standard. It does shift better, but I’m not sure that the standard shift with the extension piece on top wasn’t better placed/ more comfortable reach….. new bushes and correct set up are key regardless. </p><p></p><p>I’m on the fence still with it, I’m tempted to find a friend with a welder modify the bendy under floor rod so that the shifter moves closer to me when in neutral. Then I might have best of both</p></blockquote><p></p>
[QUOTE="Bluesnailman, post: 648231, member: 17859"] I went for the Csp shifter because it looked most like standard. It does shift better, but I’m not sure that the standard shift with the extension piece on top wasn’t better placed/ more comfortable reach….. new bushes and correct set up are key regardless. I’m on the fence still with it, I’m tempted to find a friend with a welder modify the bendy under floor rod so that the shifter moves closer to me when in neutral. Then I might have best of both [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
Winter repairs
