wiring diagram for 71 bay
frenchi
Active member
Sep 27, 2013
43
have been trying to wire up my 71 1800 bay it has stalk cotrol for wipers but on diagram it shows a dash button for wipers can any one help is there a switch or do u use stalk and ignore switch when wiring or is there a wiring diagram that shows just a stalk without switch bit confused many thanks for any help
Coda
May 25, 2020
368
30
Tewkesbury
The '71 is supposed to have a dash switch for the wipers. If you have them on the stalk it's probably been modified and you'll need to look at another diagram. Where are you getting your wiring diagrams from?
naskeet
Apr 12, 2011
272
45
Canvey Island, Essex, UK
There was no such vehicle as a 1971 VW 1800 Type 2! However, there was a 1974~75 VW 1800 Type 2, of which I briefly had one. Are you sure that your VW Type 2 is of 1971 model-year, as indicated by the third digit of your chassis number.
https://www.thesamba.com/vw/archives/manuals/8_72_bus.php
Scans of my 1973 model-year, VW 1600 Type 2’s owner’s handbook, in The Samba Archives
Most vehicles, including mine, do NOT have the intermittent wipe facility associated with switch-lever position No. 3
You might also wish to peruse the following topic thread that I initiated many years ago on The Samba "bay-window" bus forum:
Bay Window Bus > 1968~79 VW Type 2 window wiper & washer upgrades
naskeet
Apr 12, 2011
272
45
I may have a used one in my lockup, but won't be there until the weekend.
The dashboard-mounted, 1968~72 VW Type 2 windscreen wiper & washer switch can alternatively be used for a retro-fitted rear-window wiper & washer system like mine, if you ever get around to having one.
frenchi
Active member
Sep 27, 2013
43
thanks fellers for all the help much apprecated i got this bay with all stuff missing even had a beetles dash clock in it wiring was a nightmare so through every thing out just got to find a wiper switch if anyone has one / then can start making a new loom theres no wiring
67panel
Jul 30, 2009
2,521
23
malven
Sounds like a right bitsa, I would be checking the stamped chassis no against the plate and if its been ground out or welded over then I would be very suspicious.
frenchi
Active member
Sep 27, 2013
43
thanks for every ones help,,, now have all switches and loom and on way to making this right its a must to put this bay back on the road its got paperwork that covers it touring texas south america and england all with same owner
fatgaz
May 26, 2015
57
6
My 71 was built for the US market, has dash wiper switch with two speeds. But deos have a mix of loom colours which made it interesting during its refurb. My advise is get a bus electric guru who will spot stuff straight away. Good luck.
naskeet
Apr 12, 2011
272
45
Is the vehicle RHD or LHD?
If LHD, it could be of European or North American specification. If RHD, it could be of British, Australian or South African specification.
North American specification, 1968~71 VW Type 2s had a weird electrical system & loom, with some equally weird switches and rear lights.
static
Nov 9, 2006
57
88
“North American specification, 1968~71 VW Type 2s had a weird electrical system & loom, with some equally weird switches and rear lights.”
Which switches are weird? (…asked the guy with the US Spec ‘71)
pierrox
Active member
Nov 16, 2017
35
19
The US buses use the same bulb for the stop tail light and the indicator. So VW came up with a rather complex system, (yet without electronics so it's still a series of switches) for the situation when you brake and indicate that you're turning.
naskeet
Apr 12, 2011
272
45
The combination, direction-indicator cum headlamp dip switch is weird, with regard to direction-indicator connections.
North American specification, 1968~79 VW Type 2s do NOT have the headlamp flasher facility, unless someone has substituted the British & European specification, 5-terminal headlamp relay and retro-fitted a suitable red cable from terminal 30 on the fuse-box. to terminal-30 on the relay.
If your VW Type 2 is of 1971 or later model-year, you might be okay with regard to the direction-indicator flasher unit!
The USA specification, 1968~69 VW Type 2 direction-indicator flasher unit is extremely weird!
The USA specification, 1970 VW Type 2 direction-indicator flasher unit is one-year-only type, for which it might be difficult and/or expensive to find a direct replacement.
Forum Index > Bay Window Bus > 1970 VW Type 2, 4-terminal flasher, terminal configuration?
If one has a North American specification, 1968~70 VW Type 2, it would be WISE to carry a spare direction-indicator flasher unit of the appropriate type and check to make sure that it functions properly!!!
