Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Worn torsion arm bushing
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="rlepecha" data-source="post: 612774" data-attributes="member: 19679"><p>It's a relatively simple procedure if you have a decent stable trolley jack.</p><p></p><p>You need to:</p><p>mark the hub to the spring plate using paint or similar:</p><p>undo the 4-off bolts holding the spring plate to the hub</p><p>Put the saddle of the jack under the end of the spring plate</p><p>Lift the spring plate off the lower stop slightly with the jack</p><p>Lever the spring plate away from the stop and slowly drop the jack.</p><p></p><p>Once you have dropped the jack down and all the spring tension is released, the plate should just pull off. </p><p></p><p>Re-installation is the reverse.</p><p></p><p>Remember to mark the spring plate to the splined torsion bar!</p><p></p><p></p><p></p><p></p><p>Sent from my Swift 2 using Tapatalk</p></blockquote><p></p>
[QUOTE="rlepecha, post: 612774, member: 19679"] It's a relatively simple procedure if you have a decent stable trolley jack. You need to: mark the hub to the spring plate using paint or similar: undo the 4-off bolts holding the spring plate to the hub Put the saddle of the jack under the end of the spring plate Lift the spring plate off the lower stop slightly with the jack Lever the spring plate away from the stop and slowly drop the jack. Once you have dropped the jack down and all the spring tension is released, the plate should just pull off. Re-installation is the reverse. Remember to mark the spring plate to the splined torsion bar! Sent from my Swift 2 using Tapatalk [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
