Auto firestop device for engine bay
QUOTATION.
FIRETEC CT AXIAL system for VW T2 Campers
Fire Monitoring Systems manufacture an automatic fire suppression systems
for use in VW T2 campers. These are basically especially configured
Firetec CT Axial systems.
The Firetec CT equipment is described in http://www.FiretecUK.com" onclick="window.open(this.href);return false;
Specifications for use in VW T2 campers.
Cylinder: model E5. 270mm x 88mm diameter. 1.5 litres aluminium.
Tube: 3.50 metres 6.2 x 4.0 heat sensitive REACTON 80.
Valve: Stainless steel Axial valve with easy top-up external Schrader,
pressure gauge, and tube connections.
Bracket: light transport bracket, with countersunk bolt kit.
Extinguishant: special mix, 9% AFFF, non corrosive foam.
Installation options:
Upright on LH chassis leg, horizontally on LH chassis leg or horizontally
under engine compartment ‘roof’.
Buyer must state if under roof configuration is required.
Instructions:
Standard CT instructions with extra page specifically for VW T2 campers,
included.
Requires good general DIY skills, but no special tools.
Araon, Mike F.-thanks for the info! Obviously, the first step to not having an engine fire would be to install new fuel lines and make sure the carb isn't leaking-that'll be my first course of action! Then I'll consider the firetec.
