bolts or studs? 71 narrow 5 disk bay
Do you want to swap :mrgreen: I'll even throw in the wheel nuts :lol:
It was worth a try :mrgreen:
in that case you should just need studs and standard wheel nuts, available from all the suppliers.
the fuch are for sale if you're interested?
would the studs and bolts be the same as the ones fitted with the fuch? :?
How much :D ?
The studs should be ok, maybe a little longer than standard but that shouldn't cause a problem, but you may need to get new wheel nuts as the profile may be different on the wheel, try one of your wheel nuts against the steel wheels it needs to be a radius (ie rounded) profile to fit the wheel properly, Cheers Nick.
