mattd1984 said:Cheers so if you have done it have you just cut a hole in the top of the filter and run it to there? Just one of the carbs?
mattd1984 said:Ok cool, ill go for that rather than the rocker covers.
Now just to decide on the bugpack or the cb tower breather? What you think?
Zcat7 said:I've been working a lot on crankcase breathing since fitting my twin Solex carbs as I started to get some oil blowby at the stock filler neck. I have a breather box the same as Sparkywig's but the one thing I don't understand is how the oil doesn't dribble out from the lid? My version of this box is designed to be mounted with the logo facing upwards as the lid is not sealed to allow it to breath. Did you grind the little pedestals off and seal it then rely on the carbs to draw the vapour out?
No, works fine with no leaks.
My setup didn't start to work effectively until I ditched the mech fuel pump and installed a crankcase breather there. It's lead me to think that my stock breather is blocked... I now have vents in both rocker covers, the stock outlet and the fuel pump outlet.
All seems to be OK now performance/leak wise but I do fid that I get some faint oily smells when driving hard, I guess because ultimately I am still venting into the fresh air side of the engine bay through the breather box. I'm considering running a pipe to each carb to draw the fumes away.
Because you're not venting back into the carbs/air filter, so causing positive pressure in the crankcase.
Neil
six said:sparkywig what is your setup doing? are there 3 pipes? 1 is the drain to the oil filler, 2 from the carbs?
for the dumb (me) could you explain I have no idea how they work, but ti think maybe i should get one
