Iamthewalrus
Can you tell tell if cooling flaps are still there or if they are open or shut.
Can't see no thermostat though. Cheers
ozziedog said:If the flaps are there, you`ll see their axis points / fixing rods poking out of the holes of the fan housing. If they ain`t there, you`ll see the holes they should be fitted in :mrgreen:
Ozziedog,,,,,,,,,,,, Thermostats a good idea too :mrgreen:
ozziedog said:The flaps are more to do with directing the cooling away whilst the engine is warming up but I `` think `` they may aid the cooling a little because they direct it. With or without j tubes it makes no odds, it`s just that with j tubes you don`t have heating for your cab. Make sure you have all the tinware and there are no holes or missing screws, and the rubber seal is intact around the tinware.
Ozziedog,,,,,,,,, What`s the prob ??
Iamthewalrus said:ozziedog said:The flaps are more to do with directing the cooling away whilst the engine is warming up but I `` think `` they may aid the cooling a little because they direct it. With or without j tubes it makes no odds, it`s just that with j tubes you don`t have heating for your cab. Make sure you have all the tinware and there are no holes or missing screws, and the rubber seal is intact around the tinware.
Think I have all the tinware I'll take a picture tomorrow and post up.
Never had heat in cab the last two winters, cables not connected to heat exchangers, but had a fiddle with levers on exchangers last week and know got permanent heat in cab.
In this weather not good. :lol:
