No expence spared on this van worth every penny of asking price.
Basic van overview. 1972 /3 crossover year originally Danbury conversion. Full photo restoration from panels to paint to engine build.
Customised to the last. Exterior mods: Suicide doors with gas strutts and keyless entry. All handles removed and panels flushed out. Side opening deck lid on pull cord system. Tailgate opens from inside engine bay. Aluminium side step. Frenched in custom rear number plate cut into blade bumber. Front indicators frenched into blade bumber and second set of indicators inside headlights. LED angle eyes in headlights. Stainless steel mesh stone guards. Early rear lights flushed into panel. Alloy wheels with ‘blue’ bands.
Interior mods: Recaro leather front seats with retractable harness seat belts. Matching trimmed rear seats from volvo 850. Custom build interior with curved bench seat and mirror finished units. MIrror ceiling with LED interior lights. Full width hammock red. Surf board table. One piece front windows (still need a bit of work to open/close).Full stereo system Sony Head Unit JBL speakers. Scat quick shifter. Porche steering wheel.
ENGINE SPEC: 1746CC BUS ENGINE BASED ON:-
76MM FORGED C/W STROKER CRANK DYNAMICALLY BALANCED TO FORGED CHROMOLY 200MM FLYWHEEL 12LBS.
38MM CHROMOLY HEAVY DUTY GLAND NUT
85.5MM FORGED PISTON/BARRELL KIT
CB UNITECH RACE RODS
MANTON LIGHTWEIGHT 3/8 CHROMOLY PUSHRODS
ENGLE 100 CAM WITH STRAIGHT CUT GEARS
DOUBLE THRUST CAM BEARING KIT
PERFORMANCE HEADS 40 X 35.5 WITH S/S VALVES AND HIGH REV SPRINGS
CB PRO 1.4 RATION ROCKERS WITH BOLT UP SHAFT KIT
SHADEK 30MM OIL PUMP
CB WIDE SUMP 2QT
TWIN CARBS 34MM SOLEX
PERTRONIX FLAME THROWER COIL /LEADS 009 DIZZY
(HAVE PERTRONIX BILLET DIZZY WITH TAYLOR SPIRO RACE LEADS READY TO FIT- ELECTRONIC IGNITION NEEDED).
1 5/8 four into one header and stainless steel turbo muffler
2ltr Gear box with all brand new shift rods and bushes front to rear EVERYTHING changed.
Other mechanics. Gaz gas lowered shocks on front. KYB gas shocks on rear. All fixed line / flexi brake hoses changed. Late bay hubs and disks on front. Rear brake and master cylinders changed. Blubird customs adjuster on front beam. (bus very low at front great raked stance).
