slammedresto
Eberspacher and 2 gallon outboard motor fuel tank installed under westy bed. Heater control currently just the 1 hour timer, will upgrade later.
Warms up quickly, and as said previously sounds from the outside like a small jet engine, i would definatetly recommend you use the exhaust silencer, as it would be far to loud without it.
Fuel pump does make a clicking sound, but i may install this under the bus at a later stage if it bothers me too much
Exhaust and inlet pipes exit under bus, with exhaust silencer fitted to exhaust pipe.
