Having replaced the fuel lines on my bus whilst underneath I found that one of the exhaust manifold studs was missing :shock: (might explain the popping in the heat exchanger on overrun that I have had for a while).
I fitted a new M8 stud, but pulls straight out when tightened. Not sure exactly what I need to do with it now :? . Is is best to re-tap with a larger thread size, helicoil or is it a head off job to fix?
Thanks,
Si
Thanks,
Si
