J joe.m28 New member Joined Apr 3, 2013 Messages 2 Reaction score 0 Jun 2, 2016 #1 Hi has anyone had any experience of using the conversion kit so i can use late bay calipers on my 71 bay Cheers joe
W Webbaldo Well-known member Joined Mar 11, 2014 Messages 756 Reaction score 1 Jun 2, 2016 #2 If you mean early to late calipers, then yes ive just fitted it If buying separately, you need to get original or trw/varga calipers, the cheapo ones don't fit the bushes Only issue I had was I had to grind about 3mm off the corner of the fronts of the calipers to stop them rubbing on the front hub bit of the brake disc Other than that pretty simple swap over
