funny noises
super-craig
Mar 6, 2008
243
derby
while driving the 68 the other day i noticed a noise , sounds like something was rubbing when the wheels turned right , it standard ride height (almost 4x4 ish :lol: ) any ideas ? had a quick look and cant see any rubbing :? but need to get under it and have a proper look when i can
:? Is the noise on one side or is it the whole front, could be just a wheel bearing if its one side. check your flexi brake hoses are secure, sounds obvious but have you jacked each side up and span the wheels on lock?. :) :)
not had the chance to get under it yet , but the first thing is to jack it up and give em a spin 8) sat and thought about it the other day and did think about flexi hoses rubbing :shock: just put the post up just in case some else had suffered the same and would share their knowledge 8) will let you know when ive been under and sorted it out 8)
have you got drums or disks? 8)
Check your front wheel bearings. Too loose and the drum/disc rubs, too tight and bearing seizes, either state will cause noise.
