Dickie524
Morning guys, right Gearbox query this time. Is it possible for the layman to change the driveshaft oil seals, or is anything specialised required? As far as I can see there’s just a ring of dome nuts around the stub shafts – is it as simple as whipping these off and fishing the seal out?
Hr. Haynes issues fairly dire warnings that unless you aren’t taking gearboxes apart as a regular hobby then this isn’t the place to start.
The gearbox is currently out, so access is easy – am in the process of removing over ½” of 47 year old oil clag from around it! But no doubt that the driveshaft oil seals are responsible for some of it.
Also – mine being a 68 – special oil seals, of course, at £19 each, not the regular £4 ones! Such is life…
Thanks all,
/R
Thanks all,
/R
