froggy
Are modern car headlight relays 5 pin?
Im currently on my 3rd VW relay for the bay (£15 each time) due to the windscreen leaking and filling the relays full of water. The neighbour knocked on the door and said i'd left the lights on (again) the relay was shorting and flattening the battery. Anyway i've wired up some flying leads and have moved the relay out from under the fuse box until i can change the windscreen seal (was hoping to do this at the same time as re-spray but might need to do earlier) anyway this got me thinking, if a modern relay is 5 pin then i could re-wire to suit the newer relay and just get a batch load from the scrappy instead of paying £15 each time for a VW one until i can sort the leak
