froggy
Bought new inner and outer sills today from Kingfishers, would i be right in thinking:-
Cut off outer sill
cut off inner sill
fit new inner sill
fit outer sill
I know its not going to be as simple as that but if thats the correct order then at least i have a start and finish point, its going to be the bit in the middle thats will be a problem but hey ho,
Is it best to do passenger sliding door side first or drivers side, both need doing but which will be quickest to do?
Whats the best way to weld as i cant see a way of welding top of outer sill to body?
Cut off outer sill
cut off inner sill
fit new inner sill
fit outer sill
