Hi, I have come to fit the rear bulkhead tinware and I just need some clarification on a couple of things.
The tin has two lugs that sit on top of the case but not sure if the thing is sitting right? :?
the pic shows the tin sitting the gearbox side of the case across the top in parts, is this correct?
Also should the throttle cable sleeve sit at a downward angle like this?
