I need some objective help here valuing the Van. It was never an intention to sell however the little one is not happy in the back on own without windows and the missus doenst like sitting in back listening to re-runs of pepper pig!
I am in not a big rush to sell as i love it but will be gone im sure in the next few months.
Its a early (sept 1967) Cali import LHD Panel Van. 99% OG paint It was imported in 2009 I had it since Oct of that year.
The good bad and ugly details
Body and exterior:
Its had 2 front repair panels in front floor and the lip round at the bottom of the windscreen replaced and paint blended. The bad bit is it was done wrong way round so there is a little bit of surface rust on the floors but its water tight and needs a tidy.
There is a little bit of rust on each dogleg other than that imo is quiet good. Once the running gear was sorted, it was waxoyled.
bluebird pop-out rear window.
deanos most excellent westy toe-bar
JK 3 bow roof rack
Mechanical:
(work done since I have had it)
Fully refurbished front beam (Ball joints etc0 Adjusters on front beam, red9 3" lowered spring plates on rear new donuts etc.
Late bay steering box conversion
Buttys accelerator linkage.
new Master cylinder, break lines, shoes/pads, wheel cyliners flexi-pipes all round
Late bay front disks completed with new disks/pads and calipers
Repro porsche 356 chrome steels with big moon VW hubcaps excellent rubber less than 1000 miles.
Engine:
2027cc Type 1
Autolinea high roof case
Full flowed
Mahle Barrels and pistons (the good ones)
web 86 cam
1.25:1 rockers
blueprinted pump etc
CB rotary pump
compression 8.1:1
Fuel injection shroud
36 Dellorto DRLA with 32 vents
Mocal 19 row cooler with auto fan.
Vintage Speed Exhaust.
8 Dowel flywheel with Kennedy Stage 1/Kush loc clutch
GearBox:
Justin Pane t25 6 rib. tall 0.82 4th for cruising complete overhaul etc.
EMPI hurst shifter - rivits replaced with ss bolts as this is their weak point.
New bushes etc in gear shaft.
Interior:
sound deadened throughout with Spectrum Sludge or DAMPLIFIER PRO (doors roof panels the lot)
Front seats recovered vinyl
3 point belts in front, one in rear, one isofix
usual array of guages to look at oil psi/temp volts (VDO) Dakota Cyl head temp
Cab bunk
In the rear is a full width Rock and roll bead recovered along with new foam throughout.
Good quality interior with sink and big fridge for your beers
Camping battery 100AH
Reflective foil covered Ply liner and carpet covered in grey nice and cool in south of france!
Thats all i can remember, im sure there is other stuffs. Its not something id want to sell but needs must.
I think ill sell the rack tow bar and awning separatly.
some discussion on prices on options for:
1) the lot
2) van minus engine/gearbox as theses are getting expensive to build these days. selling it without might enable it to sell and ill add it to next purchase.
Plenty of pics here --> https://imgur.com/a/KAwBa
Body and exterior:
JK 3 bow roof rack
Mechanical:
Engine:
2027cc Type 1
Full flowed
web 86 cam
1.25:1 rockers
CB rotary pump
compression 8.1:1
GearBox:
Interior:
Cab bunk
1) the lot
